Question on 1999 D-1 Pins...
6l6
Real Name: Bill
Post: # 4921Post 6l6
Thu Dec 09, 2021 12:35 am
I bought my 1999 Collings D-1 new at Gryphon that year. It came with a slotted bridge and slotted sting pins. The pin slots were positioned with the slots pointing toward the bridge slots.
Does that make sense? I always thought if you had a slotted bridge you should use pins that were not slotted. Or... at least turn the slotted pins around so the slot faced towards the rear of the guitar.
Was it normal for Collings to slot their bridge and pins back in 1999? Is it the same way in 2021? Should I get some new pins that aren't slotted?
Thanks for filling me in on this.
Bill
Re: Question on 1999 D-1 Pins...
Post: # 4922Post Eric Jones
Thu Dec 09, 2021 1:25 am
That’s a beauty, Bill. I’ve had my ‘99 D1A almost as long, and I’m ashamed to say I’ve never paid attention to the pins. I’ll have to go look to see if they’re slotted. But I was under the same impression that either the pins or the bridge would be slotted.
I looked at mine and the pins are slotted. And while the bridge is somewhat slotted, it’s obviously not slotted enough to accommodate the low E string with an unslotted pin.
Post: # 4923Post Hokiebob
Thu Dec 09, 2021 4:24 am
Before 2002 Collings guitars came with slotted pins. Beginning in 2002 the pins have been unslotted.
6l6
Real Name: Bill
Post: # 4924Post 6l6
Thu Dec 09, 2021 4:05 pm
Thanks Bob!
Bill
6l6
Real Name: Bill
Post: # 4930Post 6l6
Sat Dec 11, 2021 3:59 pm
I talked with Mark at HQ.
Using slotted pins on guitars prior to 2002 is required even though the bridge is slotted.
Bill
Post: # 4994Post Greg Y
Thu Dec 30, 2021 7:39 pm
My first D1A was a late 99, early 2000. I subsequently had the popsicle brace removed and the bridge slotted to take solid pins
Wood&Steel
Real Name: John Jones
Post: # 6413Post Wood&Steel
Fri Oct 27, 2023 11:05 pm
Greg, did you have Bryan Kinsey do the work?
