collings truss rod loose in guitar
guitarfan56
Post: # 5459Post guitarfan56
Thu Apr 14, 2022 10:34 am
Truss rod is loose and can be turned by using my fingers and doesnt allow adjustments
just took strings off and tried to adjust neck
is the guitar broken now?
need input had so many troubles with that guitar im really fucking tired of it
guitarfan56
Re: collings truss rod loose in guitar
Post: # 5460Post guitarfan56
Thu Apr 14, 2022 10:48 am
the nut came off completly now, how do i put it back in?
dadgad6strings
Post: # 5461Post dadgad6strings
Thu Apr 14, 2022 11:26 am
Contact Collings. I'm sure they will be able to give some direction.
armdog
Post: # 5462Post armdog
Thu Apr 14, 2022 4:06 pm
Yes, contact Collings or.... your local dealer might be able to diagnose. hope for a quick remedy. bert
Post: # 5494Post Silly Moustache
Thu Apr 21, 2022 8:34 pm
HiIt happened to me once on my first Collings. All it means is that the truss rod is holding no tension, so loads to apply as and when necessary.
IIRC - I took the strings off and replaced it and just screwed it back on , then applied a minimum amount of tension then left it.
21 years later (when I foolishly sold it) it was still fine.
Hope that helps, Andy
guitarfan56
Post: # 5495Post guitarfan56
Sat Apr 23, 2022 2:04 pm
Silly Moustache wrote: Thu Apr 21, 2022 8:34 pm HiIt happened to me once on my first Collings. All it means is that the truss rod is holding no tension, so loads to apply as and when necessary.
I did loose tension too much and it came off
reversed it and put way higher action on it now and in fact plays much better than before
