Questions on Collings Traditional Cases
Little Strummer Boy
Post: # 2227Post Little Strummer Boy
Sun Mar 08, 2020 7:31 pm
Not sure if this is the right section, but I was wondering if anyone had information on the history of the interior linings for the Collings traditional cases. It looks like Collings switched from a blue/purple color early on to the modern magenta/purple color. How many color variations have there been, and at what serial numbers? I’m looking for a case, but I much prefer the bluer color. Are there any other changes that have been made to the cases?
Little Strummer Boy
Re: Questions on Collings Traditional Cases
Post: # 2228Post Little Strummer Boy
Sun Mar 08, 2020 7:32 pm
Also, has anyone used this case to do double duty for a modern Martin dreadnought?
Post: # 2229Post Greg Y
Sun Mar 08, 2020 8:55 pm
I'm sorry I can't help you with the lining info, except to say that Bill had purple lining in the prototype stage and then ran out for early production. My dreadnaught case (#33) has the blue lining while my OM case has the purple one. The dreadnaught case fits my vintage D18, so it should fit modern Martins.
Little Strummer Boy
Post: # 2230Post Little Strummer Boy
Sun Mar 08, 2020 11:06 pm
Thanks, Greg. I wonder if it was a decision based on availability.
JohnFrink
Post: # 2245Post JohnFrink
Thu Mar 12, 2020 9:54 pm
My 2016-era Collings OM cases (guitar SN's #26XXX) have the blueberry interior and serial numbers in the format M000000, while with my later-issue cases (#27XXX and up) have the raspberry interior and serial numbers in the format OM-000000. My highest case serial number in blueberry is 146 and my lowest number in raspberry is 282. I hope this helps.
Bourgeois OM/CB/HS, Collings OM1T, OM1Mh, OM3Mh, RainSong CH-OM, Santa Cruz OM, H13
Haasome
Post: # 2246Post Haasome
Thu Mar 12, 2020 10:08 pm
My OM #25 and OM #29 are both violet.
Post: # 2247Post Eric Jones
Fri Mar 13, 2020 1:21 pm
JohnFrink wrote: Thu Mar 12, 2020 9:54 pm My highest case serial number in blueberry is 146 and my lowest number in raspberry is 282. I hope this helps.
My highest case serial number in blueberry is 198.
Little Strummer Boy
Post: # 2263Post Little Strummer Boy
Tue Mar 17, 2020 12:13 pm
I just bought one from pto over in the buy and sell section. (My first! It is beautiful!) It is number 266 and has the blueberry color. That would put the switch from blueberry to raspberry between 266 and 282, assuming there was a single, hard transition.
adirondack&spruce
Real Name: Mike
Post: # 2423Post adirondack&spruce
Fri May 01, 2020 9:08 pm
I have two cases
D000489, blueberry color
D000539, rasberry color
Hope that helps
Real Name: George lange
Post: # 5172Post Georgelange
Sun Jan 23, 2022 1:27 am
I really miss the Collings traditional cases. I think they are making a big mistake in discontinuing those cases. All the other cases are a let down or really mixes ones are way too expensive for me
